I'm not sure either. If you are trying the 2.2, replace both the librxtxSerial.so and RXTXcomm.jar in the lib folder under TS.
With you using the 64 bit driver, make sure the librxtxSerial.so in the lib dir is a 136kbyte file on the 2.1.7 as there are 3 different ones depending on if you are 32 bit linux kernal, 64 bit x86, or intel.
It might be worth it to 1st figure out how to communicate with the terminal without using sudo.
USB device name (Linux)
Re: USB device name (Linux)
Holy moley I got it to work...
This seems like a really hacky way of doing it, but it works. I copied over the 2.2pre1 binary and JAR files, did a and to my device. Then I did a and a , ran the application under my normal user, tested the connection, and it didn't crash, told me connection was successful, and tells me I have a signature mismatch. So, what's I'm going to do later is go back to your RxTx files bundled with TS and see if it works. If it does, then it was simply a permission issue.
I'll report back for sure. Thanks guys!
Code: Select all
chmod 777 /dev/ttyUSB0
Code: Select all
chown tristan /dev/ttyUSB0
Code: Select all
chown tristan -R TunerStudioDIR/
Code: Select all
chmod 777 -R TunerStudioDIR/
1997 Turbo Saturn
MS3 v0.22
TunerStudio v[insert_current_version_here]
MS3 v0.22
