Can you import 8x8 VE tables with TunerStudio, as I keep getting a corrupt .vex file.
PS Is there a VE table generator option, as in add HP, Torque, RPM etc and get a rough approximation. I tried searching and didn't get any matches
Importing 8x8 VE Tables
Yamaha YZF1000 MSExtra 3.1
Re: Importing 8x8 VE Tables
Yes you should be able to unless I broke something....Can you import 8x8 VE tables with TunerStudio, as I keep getting a corrupt .vex file.
No, but it is on the short list to do.PS Is there a VE table generator option, as in add HP, Torque, RPM etc and get a rough approximation. I tried searching and didn't get any matches
