Phil - attached - try to open Simple msq then PID msq and then Simple msq again - you will see that PID will remain set in EGO control.LT401Vette wrote:Can you send me the Narrowband-PID.msq and Narrowband-Simple.msq you are using? There must be something more to it.
v0.989.7
Re: v0.989.7
1998 Landrover Discovery I V8 3.9, MSII/E ver RC 2.1.0 20090505; EDIS8; wideband LC-1
Re: v0.989.7
evo828,
Do you remember what stage that Simple msq was saved? There seem to be several parameters not saved in it, including egoAlgorithm (Simple / PID). Unfortunately I can't see what the raw memory looked like at that time, but this is what is supposed to happen if the memory egoAlgorithm references was not initialized with a proper value, it will not save a value for that parameter. So it was behaving as if that setting was not initialized.
Was this directly after a firmware update?
Had you connected to the controller with the new firmware yet?
Re: v0.989.7
I am not able to trace it back to the time when it initially happened. I did the firmware update some 3 weeks ago - I just realised this problem later on when on one of the edite msq I suddenly had PID instead of Simple (and the PID was not working very well with Narrowband ego). I do not create msq from blank after fw upgrade. Anyway - the msq downloaded from controller now looks well "initialised" (attached). So I will be more careful when doing some adjustments.
Re: v0.989.7
Out of curiosity.. What firmware did you upgrade from?
Re: v0.989.7
from 2.1.0 beta (05052009) to 2.1.0. release (as of 27062009).
Re: v0.989.7
Hi Phil
Just a reminder for the user settable tuning increments for the "basic" tuning (ie not using ctrl). Seems the feature did not make it into this release.
Kind regards
Philip
Philip
Re: v0.989.7
Good reminder... What happens is, once I moved out of those components I am working on completely different sections of the app. When I start skipping around too much is when I forget what I did where get into trouble
