Phil
FYI, just something I noticed the other day, if I try and edit the VE table other than use the up down triangles, I will get a TS sudden crash. Does it for the any VE table, spark table etc... doesn't do it in Windows XP though, so I am able to mod in this and USB stick it across to OS X.
Suspect it's some file mod permissions/write issue, but only guessing.
Mike
Editing RPM, bins or fuel load/kPa values (OS X only)
Yamaha YZF1000 MSExtra 3.1
Re: Editing RPM, bins or fuel load/kPa values (OS X only)
Ouch...
I don't think it would be a rights problem as nothing is persisted in doing that. It seems more like a JVM/Video diver problem maybe? There may be a pid file in the install dir. That would give a bit more indication where it is crashing.
Phil
FYI, modded an ignition table, by adding 5 deg to a couple of columns, and it locked out before suddenly crashing, here's the apple log file that the MacBook wants to send.
Hope this is of use...
Mike
Mike
