Or rather, I am doing something wrong
That is usually the case with me and software.
Have TS latest install on my ACER locost laptop, an USB/RS dongle and and MS2 Extra 2.1.0 in the MS
TS and MS2 extra , com4/115200 baud does not connect.
TS and MS1 Extra , same hardware and com4/9600 baud works great
Same MS2Extra 2.1.0 but with MT 2.25 p3 works perfectly ,com port 4 , 115200 baud)
Any hint where to start to get TS and MS2Extra 2.1.0 running will be much appreciated
Best regards
W113
MS2Extra probs with TS
If not understood , it will not work
Re: MS2Extra probs with TS
Hmmm. Try opening the mini-term, open com 4 @ 115200 and see what you get back yping a Q
If no luck, send me the TunerStudioLogFile.txt from your install dir. To p_tobin <at> yahoo.com
Great,
thanks a lot Phil.
Will do over the weekend .
Best regards
W113
thanks a lot Phil.
Best regards
W113
W113 probs with TS Solved
Phil.
Nothing was wrong with TS.
I just followed the instructions , and now all works perfectly.
Best regards
W113
Best regards
W113
