I noticed this while testing out the us. module with the newest 3.0.3h sequential code from Jean, it seems to only burn one page at a time then the popup comes up saying controller and TS dosent match you end up having to hit "Use TS settings" a few times ( depending on how many changes are in the msq) before it writes the whole msq file ,it also takes a long time to write even a fuel table.
I checked with MT just to make sure it wasn't the us. module's serial chip or something but it loads fine in MT.
Now i also checked this with a standard MS 2.2 board with MS2 card and it loads fine in TS it burns all pages the first time, it just happens with the us.Module.
I have attached the msq i was testing with this is with my desktop computer with a true serial port also running XP.
Slow msq burn with us Module
2000 Suzuki Hayabusa turbo MS3 beta testing Plug and Play standalone
http://interfacepnp.webs.com/
http://www.youtube.com/Busams
Re: Slow msq burn with us Module
Did you load the correct uS s19 file and use the correct uS ini file? Also, did you activate MICROSQUIRT_MODULE and deactivate MICROSQUIRT_FULL in the ini?
Another thing to check is the Setting CAN_COMMANDS is not on.
If that is on you will make a lot of extra calls that aren't needed unless you are communicating to it remotely.
I turned the CAN COMMANDS off and that fixed it . Thanks guys.
