Bit of a bug i think, MS1 extra ini in TS does not allow me to calibrate my TPS. It is a weber/Sierra Cosworth sensor which has 5v on open throttle and 0v closed. TS gives the error message - open should be greater than closed or such like - not in this case it shouldn't! MS2 extra allows calibration, just gives a warning.
Rick
Cannot calibrate TPS!
Re: Cannot calibrate TPS!
The MS1 code itself assumes that closed = about 0V and wide open = about 5V. This is used for accel and flood clear. So it isn't a TS issue.
so i'd have to switch out the TPS if i wanted MS1?
