I know there's some config error detection, but could it be extended such that if rpm > 65000 TS will automatically pop up a box telling the user that this is a config error and how to grab the message.
In MS3 I put the error number into the rpm.
conf_err = rpm - 65000
Would it be useful to include the error table in the ini ?
EDIT: for whatever reason, the existing config error code in TS rarely gets hit when I'm testing on the bench and I end up with a normal dash at 65000+rpm.
Feature request - config error detection
Re: Feature request - config error detection
I am planning to put in event triggers, so you can set a output channel or formula that when the condition is met, it triggers some event. That seems like a good place for this. The condition is pretty clear, then it just needs some type of notification event.
Putting predefined events in the ini seems like a good option for tying some to the firmware. You could probably put some pretty specific error messages for many errors by monitoring some bit flags or error codes.
