I have just installed my Innovate LC1 wideband after successfully getting my MS2 running last week
I have setup a gauge in TunerStudio to show me the AFR readings from the LC1. I selected the LC1 as the wideband unit from the the AFR Table Calibration wizard. When ever I close tunerstudio, the gauge defaults to an 'Exhaust Gas Oxygen Voltage' gauge, the WBO2 has defaulted back to narrow band and I have to change it again in the AFR table calibration wizard again, then change the gauge template back to AFR.
Known bug? User error or something else ?
WBO2 defaults to narrowband
'89 Toyota MR2 AW11 - 1MZFE 3L V6 - Need to finish car before ecu
'89 Toyota MR2 AW11 - 16V 4AGZE - DIYPNP 1.5v
'90 Toyota MR2 SW20 - 1MZFE 3L V6 - MS3X
Re: WBO2 defaults to narrowband
What have you set in your "Project Properties" ?
To James' point. In the Project Properties dialog (Press CTRL + P) on the settings tab, what EGO Sensor do you have selected?
CTRL + P showed me having it setup as narrowband
Thanks for helping a noob out.
EDIT: Just bought a copy of MLV, keep up the good work!
