hello all,
I have some issue when i try to connect hw with different signature.
see attached *.ini file - changed.
It seem s that I uploaded wrong file
TS log file:
TunerStudio 0.990.4 started on Sun Jan 17 13:01:49 EET 2010
JRE 1.6.0_17, Windows XP 5.1, x86
java.library.path=lib
TunerStudioMS.jar
Look:Metal, ClassName:'javax.swing.plaf.metal.MetalLookAndFeel'
Look:Nimbus, ClassName:'com.sun.java.swing.plaf.nimbus.NimbusLookAndFeel'
Look:CDE/Motif, ClassName:'com.sun.java.swing.plaf.motif.MotifLookAndFeel'
Look:Windows, ClassName:'com.sun.java.swing.plaf.windows.WindowsLookAndFeel'
Look:Windows Classic, ClassName:'com.sun.java.swing.plaf.windows.WindowsClassicLookAndFeel'
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
10-1-17 13:02:02 :Info: Initialized comm driver: 344ms.
10-1-17 13:02:04 :Debug: Opening project: C:\Documents and Settings\astralman\Desktop\piccar\sss
10-1-17 13:02:04 :Debug: EFI control 18Fv0.2
10-1-17 13:02:05 :Debug: Loaded Config in : 375ms.
10-1-17 13:02:05 :Debug: Adding Configuration: sss
10-1-17 13:02:08 :Debug: !!! Loaded config in 4875
No check, last update check=Sun Jan 17 10:56:15 EET 2010
10-1-17 13:02:09 :Debug: Monitoring COM41 @ 115200 baud for controllers.
10-1-17 13:02:09 :Debug: Started new CommThread for sss
10-1-17 13:02:09 :Debug: !!! Activated Project 5938
10-1-17 13:02:10 :Info: Comm Manager for sss Started
10-1-17 13:02:10 :Warning: Unsupported Controller Firmware.
10-1-17 13:02:55 :Debug: sss ComThread stopped
10-1-17 13:02:55 :Debug: removing Configuration: sss
TunerStudio shutdown: Sun Jan 17 13:02:55 EET 2010
TS and diffrent signature
Re: TS and diffrent signature
What hardware are you connecting to?
TunerStudio is finding something that is not a Megasquirt, so it exits.
What sort of an ini is that. It says signature="MS2Extra Rel 2.1.0p"
But that certainly is not an MS2Extra Rel 2.1.0p ini file.
A reminder.
These forums are provided for the discussion of Megasquirt products only. Discussing add-on products may be permitted, but competitor or counterfeit rip-off copies are most certainly not allowed.
Another question is how, can I stay to TS that log data is in little endian format?
Is TS support that format?
I use Megasqirt port on Microchip controller and it seems to be working with Megatune - with attached *ini file ?
10x
10x
Porting the Megasquirt code to a different controller without a specific license is a breach of copyright.
http://www.megamanual.com/copy.htm
Do not discuss your firmware here.
These forums are funded by Bowling and Grippo. If you continue to discuss your firmware here I will be forced to take the rare step of banning you.
in this case simply delete theme.
