My MAP sensor does not seem to be reading correctly and I am trying to diagnose my problem. I have the 3-bar MAP sensor from SymTech installed internally in my MS unit. I have TunerStudio installed and operating. I believe I may just have a calibration issue instead of a total MAP sensor failure. When I pull down the menu to calibrate the MAP sensor it gives me these options:
Custom
MPX4115
MPX4250
MPXH6300
GM-3bar
MPXH6400
I was using the MPXH6300 calibration and at rest the gauge reads around 200kpa. I live close to the coast so I would assume I am looking for around 100kpa. I tried the other options and they all came up with different static readings as low as ~80kpa and as high as the gauge can read.
Which calibration setting should I be using for the 3-bar MAP sensor that is installed in my MS unit?
Is there a better way to test this MAP sensor?
Thanks,
David
MAP sensor calibration
Re: MAP sensor calibration
For an update; I have MPXH6300 set. Sitting still with the motor off and with it idling my MAP reads ~200kpa. When I drive around (only down the street a few blocks) it reads around ~70-80kpa and my calibration setting automatically reads "Custom" but has the same values as before. When I got back and it was idling in the garage it was reading ~13-14kpa. It read the same after I cut the engine off. It is about 72* F outside. My engine temp reached ~185* and intake air temp was ~115*
I feel like it has a mind of its own and does whatever it wants to do.
A more intelligent thought is that the vacuum line I am using could be getting too hot and altering the readings. It's a stretch though...
I am not sure what the correct calibration numbers are for that sensor, but as for the:
It appears to always be coming up as custom? It doesn't hurt anything but could lead to confusion. I will have to look at that.my calibration setting automatically reads "Custom" but has the same values as before.
Yeah, confusion is the word of the day for me. All arrows are pointing to the MAP sensor being bad, unfortunately. I believe I will be packing the MS up and sending it back to SymTech to get tested/replaced.
