Hi, guys i tray to load a MSQ File to My DIYPNP Ecu
the ecu is using MS Extra 2.1.0p when i tray to load the MSQ File
i recived the error:
Signatures do not match!
Tune File Signature: MSExtra Rel 2.1.0q
Configurartion Signature Rel 2.1.0p
if y set yes i recived a error log:
6 Warnings:
Warning: Parameter in msq, but not valid for current firmware: No options found for Bit EcuParameter:flexport
Warning: AFRTarget not in current configuration. Value ignored.
Warning: Parameter in msq, but not valid for current firmware: No options found for Bit EcuParameter:boost_ctl_pins
Warning: Parameter in msq, but not valid for current firmware: No options found for Bit EcuParameter:launch_opt_pins
Warning: Parameter in msq, but not valid for current firmware: No options found for Bit EcuParameter:N2Oopt_pins2
how i can resolved this issue ?
thanks guy for your time
Signatures Do not Match!
Re: Signatures Do not Match!
As they are warnings they are likely harmless. However it does show that you aren't on the latest stable 2.1.0 code. So you might as well update that first in any case.
