Hello.
When I disconnect by pulling the cable (tunerstudio still running)
The idle bins in both VE and lambda delay are still highlighted
as if the car is still running. But the highlight is frozen.
Everything still works offline, but idk if that was built in. Not a problem just seems
kinda weird.
Values still highlighted after disconnect. (live tune)
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
Turbo BMW m30b35.
Re: Values still highlighted after disconnect. (live tune)
Good point, it probably should clear those. It would do the same for all tables I suppose.
