VE Analyze Live Help
This may be a easy fix. I am not great with megasquirt but I cannot get ve analyze to work with the my aem wideband. I get a message that says error creating VE Analyze Console. Unable to create BinTable Root Problem:null. I only get this with AEM-30-42xx if i select a different wideband ve analyze works fine.
Re: VE Analyze Live Help
MS1, MS2 or MS3?
MS1 I'm guessing?
MS1 I'm guessing?
You are correct MS1
Anyone have any ideas? I would really like to use VE analyze thanks!
opps, I think I dropped this thread..
But I did fix the file I think.
Try replacing the lambdaSensors.ini file in:
c:\Program Files\EFIAnalytics\TunerStudioMS\inc\
with the attached. That _should_ work..
Hmm still is doing the same thing I took a screen shot for you of the error. Also I attached a copy of my ini,if you use that when starting a new project and then select the aem 30-42xx it should reproduce the error when clicking on the VE analyze tab. I also get the same error when trying to open the afr targets table. Thank you for your help!
http://s4.photobucket.com/albums/y132/b ... studio.jpg
Best if it isn't to much trouble. Zip up your project folder less the log files and send it to me.
Email sent! Thanks
I see the problem... You are running on 29k, that doesn't have the AEM_LINEAR setup. The 29y ini that is included with TS does.
So you either need to migrate the entries fromt he 29y ini to yours, or upgrade to the 29y4 firmware.
But this does point out a need to filter that list to valid options... The AEM_LINEAR shouldn't be offered if it doesn't work with your ini.
Oh ok! I will most likely just upgrade. Thanks for all they help!
