setting lambda delay
LT401Vette
Re: setting lambda delay
Post by LT401Vette »
I'm betting that the High RPM / High MAP settings are too high. Even if you have a long travel to the Lambda sensor, the High MAP especially in the High Map is still fast. It is the low RPM low MAP that get slower
nuvolarossa
Post by nuvolarossa »
LT401Vette wrote:It would probably be god to have some sort of wizard to set the default delays.
you have plans for this? estimate release date?
thanks
Robert
MS3x 1.4.1 | TS 3.0.28
Rick Finsta
Post by Rick Finsta »
Phil, did this idea (table generator) get scrapped?
seijirou
Post by seijirou »
Sorry for the resurrection but a lambda delay wizard would be nice!
panel
Post by panel »
Bump :)
'65 VW Bus with a Subaru EJ20 Turbo conversion , Air to water I/C , LS coils , 14Point7 Spartan 2 & Solid Air Fuel Ratio 52mm gauge.
MS2 Extra V3.0 board
vw_chuck
Post by vw_chuck »
Yea this is needed bigtime.
Blue Coupe
Post by Blue Coupe »
Support for a wizard.
If the data is in a log, wouldn't it be best just to recommend a table based off a log?
I'm all for removing one less manual activity.
1988 Mustang, 357W Clevor, 12.5:1 pistons, 2bbl Cleveland heads, Street Boss intake converted to EFI, 30lb/hr injectors (Red Tops), MS3.57 Extra, Full Sequential Injection, 190L/hr pump, TFI, MSD 6AL, T5 transmission.
Zaphod
Post by Zaphod »
Yeah, such a wizard would be very nice!!!
fun is not a straight line
Sven
Mr. Hawver
Post by Mr. Hawver »
I'd also really like to see the delay wizard.
1995 GT Mustang
302 SBF, Trick Flow Twisted Wedge heads, Trick Flow Stage 1 cam, Edelbrock Performer intake
MS3X, Hall 36-1 crank, Hall cam, Ford slot MAF, 2x 14point7 Spartan 2 WBO2, D585 coils, 42 lb/hr Bosch fatties
mapdaddy
Post by mapdaddy »
Great idea on the wizard, hope this is not forgotten
Steven VanOrder
Post by Steven VanOrder »
+1 for the wizard
NigeT
Post by NigeT »
+1
Sent from my SM-N950F using Tapatalk
terryly
Post by terryly »
Another vote for a wizard
mal
Post by mal »
Found this thread while trying to figure out the best way to set the AFR delay... This process seems ripe for an "autotune" to set the delay..
So, +1 on this feature request!
dll67
Post by dll67 »
Another vote for a delay wizard .. My setup seems particularly sensitive to the effects of an inaccurate wbo2 delay.
MS3PU/IOx/CAN-EGT/DBWx2 540ci BBC 325cc int runners (2)innovate LC2 wbo2's, Hilborn ITB injector cnvrtd to EFI, 55LB Inj, d585 coil near plg, 60-2 trg whl & cam ph snsr, Muncie 4spd w/10T VSS, Tilton 7.25" cerametalic cltch 8.5LB flywhl
Malic
Post by Malic »
Has there been any update on this tool?
Would love to be a beta tester, as it would be tons better then whatever I have.
I tried to do everything scientifically, set up a button to switch between two fuel maps and measuring on MLV, but none of the values seem to work. Held as a stable value, and measured between when the button was pressed and when the AFR reaches the first peak of the second fuel maps stable AFR to measure the transition. Numbers have been equal pressing or releasing the fuel map button, is just autotune just seems to be worse and worse.
Malic
Post by Malic »
Still hoping for a tool, even one just to test
Malic
Post by Malic »
Just checking to see if this is still a thing being worked on. My tune just seems to add fuel on one run, then take it away on the next, but I cannot narrow down the delay to make it find the right fuel autotune.
NigeT
Post by NigeT »
+1
Sent from my SM-N976B using Tapatalk
mk1rocc
Post by mk1rocc »
+1 would be great to have this , if not completely automated at least a semi auto way :D
