Page 3 of 4
Re: setting lambda delay
Posted: Fri Oct 01, 2010 5:22 pm
by LT401Vette
I'm betting that the High RPM / High MAP settings are too high. Even if you have a long travel to the Lambda sensor, the High MAP especially in the High Map is still fast. It is the low RPM low MAP that get slower
Posted: Tue Oct 05, 2010 1:29 am
by nuvolarossa
LT401Vette wrote:It would probably be god to have some sort of wizard to set the default delays.
you have plans for this? estimate release date?
thanks
Posted: Mon Sep 14, 2015 5:40 pm
by Rick Finsta
Phil, did this idea (table generator) get scrapped?
Posted: Thu Apr 13, 2017 11:12 am
by seijirou
Sorry for the resurrection but a lambda delay wizard would be nice!
Posted: Sun Sep 16, 2018 7:40 pm
by panel
Bump
Posted: Wed Sep 19, 2018 7:05 am
by vw_chuck
Yea this is needed bigtime.
Posted: Sun Jun 09, 2019 8:48 am
by Blue Coupe
Support for a wizard.
If the data is in a log, wouldn't it be best just to recommend a table based off a log?
I'm all for removing one less manual activity.
Posted: Wed Jun 12, 2019 6:20 am
by Zaphod
Yeah, such a wizard would be very nice!!!
Posted: Wed Jun 19, 2019 5:05 am
by Mr. Hawver
I'd also really like to see the delay wizard.
Posted: Fri Jun 21, 2019 5:20 am
by mapdaddy
Great idea on the wizard, hope this is not forgotten
Posted: Fri Jun 21, 2019 6:39 am
by Steven VanOrder
+1 for the wizard
Posted: Sat Jun 29, 2019 6:56 am
by NigeT
+1
Sent from my SM-N950F using Tapatalk
Posted: Tue Jul 02, 2019 5:59 am
by terryly
Another vote for a wizard
Posted: Wed Jun 17, 2020 12:55 pm
by mal
Found this thread while trying to figure out the best way to set the AFR delay... This process seems ripe for an "autotune" to set the delay..
So, +1 on this feature request!
Posted: Fri Jul 24, 2020 4:10 pm
by dll67
Another vote for a delay wizard .. My setup seems particularly sensitive to the effects of an inaccurate wbo2 delay.
Posted: Wed Feb 03, 2021 3:33 am
by Malic
Has there been any update on this tool?
Would love to be a beta tester, as it would be tons better then whatever I have.
I tried to do everything scientifically, set up a button to switch between two fuel maps and measuring on MLV, but none of the values seem to work. Held as a stable value, and measured between when the button was pressed and when the AFR reaches the first peak of the second fuel maps stable AFR to measure the transition. Numbers have been equal pressing or releasing the fuel map button, is just autotune just seems to be worse and worse.
Posted: Thu Apr 15, 2021 6:01 am
by Malic
Still hoping for a tool, even one just to test
Posted: Thu Jun 24, 2021 12:50 am
by Malic
Just checking to see if this is still a thing being worked on. My tune just seems to add fuel on one run, then take it away on the next, but I cannot narrow down the delay to make it find the right fuel autotune.
Posted: Thu Jun 24, 2021 5:04 am
by NigeT
+1
Sent from my SM-N976B using Tapatalk
Posted: Tue Jul 06, 2021 8:34 am
by mk1rocc
+1 would be great to have this , if not completely automated at least a semi auto way
