sw bugs in version 999.2?
HI, I'm facing two problems when using MT version 999.2 on my MS1V3 29y4 (as a registered user):
1. the AFR-target tables changes after save/reload to a different value compared to what I manually entered first ... what is happening?
2. I seem to have lost the load or save VE- or SPARK-table in the tuning submenu ... where did it go to?
Re: sw bugs in version 999.2?
Do not use 999.2. Upgrade to 999.3.
1) What type of changes? What WB Controller are you using?
In some cases on MS1, the WB Controller AFR to Volt conversion is too coarse to hold .1 AFR. So when the AFR value is converted to the voltage ADC value it will need to be rounded to the closest ADC, and in turn becomes a new value.
2) There are buttons on the toolbar to import and export... I need to add some menus.
I see, just discovered the function of the yellow arrows. :0
It's on LC1 and after setting 14.7 in many fields, it sometimes becomes 14.9, sometimes 14.8 after save/reload tune. By the way, (nearly?) all fields in the afr-table get incremented by .1 or .2.
with version 999.3 on windows XP, the afr-table remains stable; so it is either a 999.2 issue or a windows7-issue; will upgrade to 999.3 on my windows7 notebook and report back
the afr-table remains stable now on version 999.3 (on windows 7)
As I posted above - do not use 0.999.2 it is known to be a bad release.
