TS 6c does not re-establish comms after my carPC (XP) hibernated. Previous versions of TS did (cant be sure which). I need to close TS and restart the application for comms to be re-established. Going offline (via file menu) and online does not help either.
LT401Vette wrote:Do you know if 999.1 or .3 worked there? I will have to check into that. Are you using the same serial connection?
LT401Vette wrote:When you try to do the online via the File menu does it just not respond or is it causing the app to hang?
Philip Lochner wrote:TS 6c does not re-establish comms after my carPC (XP) hibernated. Previous versions of TS did (cant be sure which). I need to close TS and restart the application for comms to be re-established. Going offline (via file menu) and online does not help either.
Also.. Datalogging when I have a CAN device defined in the project.. Does it datalog parameters from both in the same log?
LT401Vette wrote:Does the OutputChannel "pwm1_countH" mean anything to you?
On each outpc post there is an error getting the value for this OutputChannel and in the 0.25 MS3 code i don't see such an OutputChannel defined
