Changing coolant temp value on one screen changes others
For discussion of Phil Tobin's Tuner Studio software
Postby whodwho » Wed Jul 21, 2010 7:40 pm
Is the coolant temp scale of the PWM Idle Duty Cycle and warmup Enrichment Curve supposed to be tied together? When I change one it changes the other one.
Version v0.999.3
Edit: now I see the same for Afterstart Enrichment, Cranking pulsewidth and priming pulsewith screens are tied together
whodwho
Re: Change coolant temp value on one screen changes other - Bug?
Postby LT401Vette » Wed Jul 21, 2010 8:06 pm
That is actually a firmware question, so to answer it correctly you would need to state what firmware you are running.
LT401Vette
Postby whodwho » Wed Jul 21, 2010 8:36 pm
It is 3.0.3u with shows up as 3.0.3s
This was really screwing with me, now that I know it does that I can work around it but do know if it has always been that way?
Sorry to assume it was TS, I will try to change the title and take Bug out of the title.
Thanks for the great work and a quick response.
whodwho
Re: Changing coolant temp value on one screen changes others
Postby jsmcortina » Thu Jul 22, 2010 1:44 am
Yes it has always been that way and it is the way the firmware is written. It originates from MS2/BG.
I can supply, repair or upgrade Megasquirts in UK
Postby whodwho » Thu Jul 22, 2010 6:20 am
Thanks James for the confirmation.
So knowing that I can work around it but sure screwed with me for a while and can't say I ever read that anywhere to watch for that.
Thank you both :D
whodwho
Return to Tuner Studio
Users browsing this forum: Google [Bot] and 1 guest
