LT401Vette wrote:I would check you connections and the output of the wire you have connected to the MS. It sounds like an electrical problem
LT401Vette wrote:That is interesting that the AEM is working as expected on an MS2 and not on the MS1. It should be more or less the same math...
I still don't understand why the AEM doesn't seem to work to the published output, but thought this was for all MS's, not just MS1. It is the same hardware, just an 8 bit ADC vs a 10 bit.
We've had a couple AEM users measure their output voltages and confirmed they really don't match the published output. It appears they start drifting from the published specs after a couple years in service, or it may be that earlier ones were built with less precise components.
Tjabo wrote:From back when I was on MS1, there was an elaborate work-around for this problem that could be input into the .ini file in MegaTune. I think if you googled something about it related to "Plastic Racing" or Plastik Racing" you might find it. It was written up by a guy who was "Squirting" a Saturn (who might still frequent this board). Not knowing how the two programs are similar or differ, I can't say whether the same solution would work.
To be simplistic, you can just adjust your AFR targets accordingly, or my best solution was to upgrade to MS2/Extra, which fixed the problem and came with a multitude of other niceties. The AEM Uego also works perfectly with MS3, so if you're going that direction you're in good shape too.
I am still very wary of going WOT as I am afraid of how much it has leaned out my top end with the differing readouts between gauge and laptop.
LT401Vette wrote:I am still very wary of going WOT as I am afraid of how much it has leaned out my top end with the differing readouts between gauge and laptop.
Caution should be taken if you are running heavy WOT. Typically I just leave the "Update Controller" check box unchecked if you are doing much WOT. Then it will still generate the corrected table, but won't send it to the controller until you have had the chance to review it an make sure it passes the sanity check. I'm no worried about it correcting wrong, that is the same math that is used everywhere, the concern is more around if something isn't right like a bad lambda sensor. Most of these conditions TS tries to detect and stop correcting, but everything can not be.
Leaving Update controller unchecked make it pretty safe, no data is sent until you click send.
Users browsing this forum: Apocolipse, elaw, Google [Bot] and 2 guests
