by everlast » Thu Jul 29, 2010 2:07 pm
Here is SlimFull, my (somewhat failed) attempt at a low CPU, high performance dash. In incorporates only the things I need, not for everyone but it has some good tidbits that others could benefit by. The screenshots are simulated; I'm not near my car at the moment, so no histograms work.
- shift light -
A horizontal bar rpm gauge. It's range is 1 rpm, set where you want it to light up. It has a transparent face and font, with a warning color that coincides with the top of the range, so it simply goes from black to pink in 1 rpm, say 5799 to 5800. I put an indicator in front with the word SHIFT in black, attached to a "null = 0;" output channel in my custom.ini for performance.
- dual afr / target histogram -
This is super handy; it shows the AFR and target on top of each other, like MLV does. Great for quick glances. I used spaces to move the labels around. AFR Target needs an entry in custom.ini to divide by 100 to get it to work, fyi.
- histograms -
The histograms are all the same vertical limits, so they are comparable to each other easily.
- ase, cl idle and wse -
These indictators are dark in the screen shots. They go dark when out, so not to clutter the screen.
- tps -
Your typical bar graph for TPS, with a label indictor with the numeric value. The bar graph limits are 0 to 100, but the numeric one goes from -50 to 150. When out spec, it lights up yellow to alert you that you need to calibrate your TPS.
- ego -
It gently lights up whenever ego correction is in use, and goes black at 100%. Easy to spot when EGO is active at a glance.
- invisible gauges -
The lost sync counter, warm up enrichment and (not visible) Config Error gauges are invisible when unlit, decluttering the screen. No use having them on when they're not used. The Lost Sync is visible from a count of 1 and up.
- main RPM gauge
The tach uses a standard circle gauge, with a black circle nulled gauge to cover the middle, transparent fonts and a bar gauge for the labels (because the labels on the circle gauges suck). Also give a nice ring effect around the tach.
Performance isn't as good as I'd hoped. My machine is horribly slow (CPU index of 12000 or so) so I can't except much I guess.
Phil, I'd love to know what gauges zap the most CPU. Do histograms take more CPU when they're wider?
- Attachments
- slimfull1.jpg (40.22 KiB) Viewed 831 times
- slimfull2.jpg (53.46 KiB) Viewed 831 times
