That is quite doable.Greg G wrote:Would be cool if TS could support a second screen. Then you could have the static gauges on the second monitor and still tune with the primary screen
The official "Post your custom-from-scratch dash" thread
Re: The official "Post your custom-from-scratch dash" thread
The gauges inside the bezel is pretty cool.. It takes a second glance to see they are not real.
If I ran the full cluster I would use two screens, something like two 4.5" x 9" or something like that with a car computer. Then just use either a usb or wireless mouse and keyboard to tune with on either a third screen or shut down one of the two screens temporarily. Still something I want to do, but it's low on the project list (and I need to figure out how to convert a VSS signal off the trans into something speedo like and really don't want to loose the odometer function).
just thinking aloud, too bad old smart phones and/or their screens couldn't be re-purposed as individual gauge monitors. I like the bezel in front of the display a lot!
'98 Trans Am LS1 A4
Ms2 3.0 board, controlling fuel and spark.
TheSilverBuick wrote:I just got signed up for the forum but have been browsing for years. I've had a MegaSquirt on my Buick since 2009, and on my Thunderbird I think in 2008.
I've contemplated going to a digital dash on my '77 Skylark behind the stock dash cluster trim. This is just playing around against the laptop screen.
Now that would be pretty sweet. Probably would not be difficult to implement, i would use just one screen and center it perfectly.
Here is mine:
CSU Long Beach Formula SAE
Last week I ordered a 9"x5" screen to do a half cluster. If I actually get it mounted in the car I'll post up pictures of the results.
This is the dash I came up with to tune the newest MS3 MS3x installs I am working on. The car has a Ford MAF built into the intake for testing. Right now it is not controlling fuel. The gauge in the bottom right has Duty Cycle on the perimeter and MAF percent in the center.
I do a similar trick with Target AFR and AFR.
see hhttp://www.ncs-stl.com/Ms3BetaTesting/MAF/MS3_SD_MafLog.dash
This car is a SCCA racecar.
Andy
Andy
Well, thought I'd give a go. Saw a request for an LFA style dash. I was blown away by the design when I first saw it, so that's what I've done.
I have the background image in C:\Program Files (x86)\EFIAnalytics\TunerStudioMS\Dash\Backgrounds\lfa_dash.jpg However, you can put it anywhere, just update the background location.
very nice!!!
is it safe to load a ms3 dash into a computers using a ms2
Yes, any dash is safe in that it can't hurt or change your controller settings. What you may end up with is a few broken gauges or indicators that are assigned to OutputChannels that don't exist for your firmware. These will have a red circle and cross through them. You can fix them by right clicking on them and selecting a valid gauge type.Swagon_wagon wrote:is it safe to load a ms3 dash into a computers using a ms2
Here's mine...
Zamora running at Renault Clio mk2 ph2 1.0L 16v ms3/ms3x...
2.0L supercharged comming soon...
Wow. You guys are really stepping it up! Very nice!
'98 Trans Am LS1 A4
I have not made a dash or even started tuning yet, i saw the LFA style dash, that was awsome, same as the ferrari dash, but if i may put a chalange out there for somone to design a lambourgini aventador dash?? They look cool
2002 Lexus IS300
Precision 70mm Turbo
First attempt. Playing with the dashboards is a lot of fun
I will eventually complete this with more gauges and more lifelike styling
1991 BMW 325i
Genius that's just like my real dash fancy sharing it?
Made this one up tonight. Nothing fancy, just a quick way of getting the info I need in a clear way. Since it's a 1970s British sports car, I thought a wooden dash with black gauges would be fitting.
http://triumphspitfire.rickbaines.com/f ... redash.png
Triumph Spitfire 1500 - MS3 + MSX running sequential injection with direct coil control.
Here is my custom dash(not even sure it could be called custom). Simplistic but gives me all the info I really look for . Im blind in one eye so I have reduced depth perception and find analog gages difficult to see at a glance. Basic readout works for me .P.S. Imagine what its like to try to watch a 3D movie with 1 eye.. It dont work
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Getting closer to installing the digital cluster. Built a car computer and ran a first pass test the other day and last night I got it to auto-start an ad hoc network so I can remote desktop my laptop into it, which will allow me to make changes to the gauges after it's installed so the bezels covering the various menu's won't be a problem.
Right now its about a 15-20 second lag time from a cold start and I have it timed to stay on for 2 hours after the key is turned off or if battery voltage drops to 11.5v. So stopping for gas, food, etc shouldn't cause it to restart and need another 15-20 seconds unless I'm really stopped for a while. The monitor power will be wired in separately from the computer so it won't be drawing on battery power when the key is off.
http://www.youtube.com/watch?v=b0i8hMPLfY8
I fixed my broken picture links on the last page.
