Gear Indicator
Gear Indicator
I noticed that the way the gear indicator works is reverse is -1 and neutral is 0. Would it be possible to switch those to R and N respectively? Not a huge thing, but it's a bit weird seeing your dash say you're in "negative first" gear.
1992 Volvo 740 Wagon - Beater Car...CAI, 16T, catback, MS3/MS3X, & HID's
1996 Eagle Talon TSi AWD - Daily Driver...RAI, Big 16g, 3" TBE, HID's, etc.
Re: Gear Indicator
That is exactly how I designed it. Reverse IS negative first gear - you go backwards.
Re: Gear Indicator
I know, I know....I'm just saying, it it possible to make it display R & N, or does the gear output have to be an integer?jsmcortina wrote:That is exactly how I designed it. Reverse IS negative first gear - you go backwards.
Re: Gear Indicator
just create a few indicators with formula GEAR == -1, GEAR == 0, etc and overlay them.VolvoGuy50 wrote:I know, I know....I'm just saying, it it possible to make it display R & N, or does the gear output have to be an integer?jsmcortina wrote:That is exactly how I designed it. Reverse IS negative first gear - you go backwards.
2020 BMW X3M - bm3 - stage1
1994 Supra - ms3pnp pro - j&s
Re: Gear Indicator
Didn't know I could do that. Thank you for the hint.gurov wrote:just create a few indicators with formula GEAR == -1, GEAR == 0, etc and overlay them.
Re: Gear Indicator
OK, so I've finally gotten around to prepping my dash for use in the car. I want to fix this gear thing (I'm picky, ok?). Based on gurvo's post, I need to create a new indicator. I'm not exactly sure how to do this. I know I obv. need to add an indicator to the INI, but I'm unsure of where to put this. The normal gear indicator is actually a gauge, likely because it has more than two values. Could someone please give me a pointing in the correct direction?
Re: Gear Indicator
You can create the indicators by going into designer mode, then right click on the dash and select:
New --> Add Indicator
You will need to set the On Text and Off Text, set the off text to nothing and the on text to the gear.
You will need to set each indicator to an output channel that yields a boolean value.. That is where you will need the following in the ini.
Create a custom.ini file with this in it:
Put that custom.ini in the projectCfg dir of your project. Then back in TS, those OutputChannels will show up in the list of available OutputChannels. Assign one to each Indicator in a stack.
This will get the job done, but it is a work around hack due to a limitation. I will fix that.
Code: Select all
[OutputChannels]
reverse = { gear == -1 ? 1:0 }
neutral = { gear == 0 ? 1:0 }
gear1 = { gear == 1 ? 1:0 }
gear2 = { gear == 2 ? 1:0 }
gear3 = { gear == 3 ? 1:0 }
gear4 = { gear == 4 ? 1:0 }
gear5 = { gear == 5 ? 1:0 }
gear6 = { gear == 6 ? 1:0 }
Re: Gear Indicator
Awesome! Thanks Phil! That did the trick!LT401Vette wrote:You can create the indicators by going into designer mode, then right click on the dash and select:
Put that custom.ini in the projectCfg dir of your project. Then back in TS, those OutputChannels will show up in the list of available OutputChannels. Assign one to each Indicator in a stack.Code: Select all
[OutputChannels] reverse = { gear == -1 ? 1:0 } neutral = { gear == 0 ? 1:0 } gear1 = { gear == 1 ? 1:0 } gear2 = { gear == 2 ? 1:0 } gear3 = { gear == 3 ? 1:0 } gear4 = { gear == 4 ? 1:0 } gear5 = { gear == 5 ? 1:0 } gear6 = { gear == 6 ? 1:0 }
Re: Gear Indicator
Holy thread revival!
In preparation for gear based boost control, I want to add a gear indicator to my TS 2.6.02 dash. I expected to spend about 30 seconds looking for "gear indicator" in one of the new gauge pick lists. I must be blind cuz I'm not seeing it.
I've already programmed my 1.3.1 MS3 for VSS/RPM detection and burned my gear ratios.
Is there a canned indicator for me to pick, or must I do the custom ini file trick Phil describes above?
Jeff
Jeff
Re: Gear Indicator
Hello Jeff,9secz wrote: I want to add a gear indicator to my TS 2.6.02 dash. I expected to spend about 30 seconds looking for "gear indicator" in one of the new gauge pick lists. I must be blind cuz I'm not seeing it.
perhaps this helps:
(its also there in the unregistred version)
But i dont know the TS 2.6.02 as it seems to be a beta version.
Maybe you should try the latest stable 2.6.01
Re: Gear Indicator
The TS version wouldn't matter here, that is defined in the ini for the 1.3 firmware. It is probably just that there are so many defined it can be hard to find the one you are looking for. Maybe there should be a search on that menu
Re: Gear Indicator
Thanks for the screen shot - now I see it.
Edit to say that having my laptop know what gear I'm in is pretty sweet. So far it's speaking the truth unless I do something obvious like drop into neutral and coast at highway speeds.
Jeff
Jeff
Re: Gear Indicator
Is it possible to create a gear indicator for ms2?
Im thinking of a pot meter on the sequential shifter on a motorbike.
And then make a custom.ini with the values translated to gearvalue.
examples?
examples?
Re: Gear Indicator
Yes.
You could create a couple channels in the custom.ini / Custom Configuration Editor (in TunerStudio MS Ultra) that take a stab at deriving the gear. Naturally there will be some error if not planted firmly in a gear.
That would be for a 4 speed, more gears, keep going out.
You can try these formulas out in MLV with existing log files to see if they work for you.
Code: Select all
[OutputChannels]
transGearRatio = { ([tireDiameterInInches]*rpm)/(335.675 * [finalDriveRatio] * speedInMPH) }, ":1"
detectedGear = { transGearRatio < numHalfBetween1and2 ? 1 : transGearRatio < numHalfBetween2and3 ? 2 : transGearRatio < numHalfBetween3and4 ? 3 : 4 }
Re: Gear Indicator
It is also worth noting you no longer need to stack indicators like above with TS 3.0+
There are String functions that allow you to display string valued based on an expression value.
Putting the above in a custom.ini file on an MS3 where gear is already known as -1 through n will add an indicator to your right click menu that will display:
Gear: R
Gear: N
Gear: 1
Gear: 2
Gear: 3
Gear: 4
Code: Select all
[PcVariables]
gearDisplay = bits, U08, [0:2], "R", "N", "1", "2", "3", "4", "5"
[FrontPage]
indicator = { gear %2 }, "Gear: bitStringValue( gearDisplay , gear+ 1 )", "Gear: bitStringValue( gearDisplay , gear+ 1 )", white, black, green, black
Gear: R
Gear: N
Gear: 1
Gear: 2
Gear: 3
Gear: 4
Re: Gear Indicator
Hi again.
I want to make gear indicator with ms2, and use a pot on an6 for input signal.
ex:
1gear - 1v (or adc)
neutral - 1.5v
2nd - 2v
3rd - 2.5v
4th - 3v
5th - 3.5v
how can I do this? I thougt make an .inc file and then numerius display, but it is possible to get indicators from .inc file as well?
ex:
1gear - 1v (or adc)
neutral - 1.5v
2nd - 2v
3rd - 2.5v
4th - 3v
5th - 3.5v
Re: Gear Indicator
no need for an inc file. Use the above, but set the index based on the adc value.
Re: Gear Indicator
Hi!
I'm helping Red Racing with this gear indicator and we're trying to figure this out.3
This is what I have done so far:
[OutputChannels]
deadValue = { 0 } ; Convenient unchanging value.
GearInput_analog = { (adc6/1023)*5 }, "VOLT"
GearInput_analog_test = { 2 }, ":1"
detectedGear1 = { GearInput_analog > 1.5 ? 1 : GearInput_analog > 2.5 ? 2 : GearInput_analog > 3.5 ? 3 : 4 }
Could you please guide us through this procedure? Would really appreciate it as we're both kinda green here
[OutputChannels]
Re: Gear Indicator
I assume the goal is 1V = 1st gear, 2v=2nd, etc?tmbryhn wrote:Hi!
[OutputChannels]
Looks good so far, but the > is backwards.
Try this:
Code: Select all
[PcVariables]
gearDisplay = bits, U08, [0:2], "N", "1", "2", "3", "4", "5", "INVALID"
[FrontPage]
indicator = { gear %2 }, "Gear: bitStringValue( gearDisplay , detectedGear1 )", "Gear: bitStringValue( gearDisplay , detectedGear1 )", white, black, green, black
[OutputChannels]
Re: Gear Indicator
Thanks!
I just copy/pasted and It's working!
... but, funny thing. The indicator won't refresh correct gear value before there are other changes in analog input variables, such as WB, CLT and IAT.
I can change and thrack the analog input value on adc6 and "Gear voltage" variable and notice that the voltage change in real time, but the indicator itself won't be updated before there have been another change in any of the above mentioned (and probably other) variables.
I have tried to set all the input lags to 100 (first thing that crossed my mind).
Any ideas?
Any ideas?
