TunerStudio MS 1.0 Released
Postby LT401Vette » Sun Mar 20, 2011 10:45 am
This version of TunerStudio has been thoroughly tested by thousands of users.
I want to thank all those who have tested earlier versions and provided feedback.
For anyone new to TunerStudio, TunerStudio is the current main stream software for MegaSquirt supporting all version of MegaSquirt and continues to be actively developed.
The unregistered lite version gives all capabilities needed to set up and tune your controller but is far more feature rich and refined than the predecessor applications, registration is not required. If you choose to register, it supports the development effort and does bring you some cool additional features like VE Analyze Live Automated Tuning and designer dashboards.
If you are still using MegaTune, the transition is very simple and you will find almost everything in the same place, but even the Lite version has many more features and easier usability.
Download 1.0 at:
http://www.tunerstudio.com/index.php?op ... &Itemid=40
or
http://www.efianalytics.com/TunerStudio/download/
It is also available via Auto Update.
So finally it is getting a 1.0 version, this allows the bigger enhancements to come back into the beta stream.
The first big upcoming change is Multi-language support, Automatic Restore Points, Tune log....
For those who want to get all the latest beta features, download from:
http://www.efianalytics.com/TunerStudio/beta
LT401Vette
Re: TunerStudio MS 1.0 Released
Postby elaw » Sun Mar 20, 2011 11:21 am
Phil... thanks for all your hard work on this! It must be nice to finally be able to call it "1.0"! :D
Eric Law
elaw
Postby dan187 » Sun Mar 20, 2011 11:27 am
Great software, good work.
However, I just updated to v1. Right before the update my temp sensors were correct, after update the software reloaded and the readings are now too low (just as if the calibration is wrong). Could you suggest a solution for me?
I've checked and the inc files are still in the project folder.
Regards
Dan
dan187
Postby LT401Vette » Sun Mar 20, 2011 11:34 am
What version were you using before?
What firmware are you using?
Are you using custom inc files like produced from EasyTherm?
Are you sure you were using the inc files from under the Project dir and did not put the inc files in the inc dir under the installation folder?
LT401Vette
Postby dan187 » Sun Mar 20, 2011 11:58 am
Thanks for reply.
Unfortunately, not sure of the previous version. I would imagine it was the previous latest. I think it updated end of Feb.
Megasquirt 1 extra. Version 029y4
Yeah custom files from easytherm
Pretty sure its the right location: C:\Users\Dan\Documents\TunerStudioProjects\Ronnie\inc
Dan
dan187
Postby 93white3400z » Sun Mar 20, 2011 12:36 pm
Hi Phil, I might have found an issue.
I'm opening an old MS1 MSQ and ask me for an INI, I select it and I get an NPE like so:
TunerStudio 1.0 started on Sun Mar 20 15:34:27 EDT 2011
JRE 1.6.0_24, Windows 7 6.1, x86
java.library.path=lib
TunerStudioMS.jar
Look:Metal, ClassName:'javax.swing.plaf.metal.MetalLookAndFeel'
Look:Nimbus, ClassName:'com.sun.java.swing.plaf.nimbus.NimbusLookAndFeel'
Look:CDE/Motif, ClassName:'com.sun.java.swing.plaf.motif.MotifLookAndFeel'
Look:Windows, ClassName:'com.sun.java.swing.plaf.windows.WindowsLookAndFeel'
Look:Windows Classic, ClassName:'com.sun.java.swing.plaf.windows.WindowsClassicLookAndFeel'
WARNING: RXTX Version mismatch
Jar version = RXTX-2.2pre1
native lib Version = RXTX-2.1-7
11-03-20 15:34:27 :Info: Initialized comm driver: 12ms.
11-03-20 15:34:27 :Warning: Unable to set Main cluster for title:
arg found 0:C:\Users\Seb\AppData\Local\Temp\TurboProject_2007_06_22-1.msq
11-03-20 15:34:29 :Debug: No Config File found, prompting user.
No check, last update check=Sun Mar 20 14:02:21 EDT 2011
Exception in thread "main" java.lang.NullPointerException
at com.efiAnalytics.util.N.a(Unknown Source)
at com.efiAnalytics.tunerStudio.f.c(Unknown Source)
at TunerStudio.main(Unknown Source)
MSDroid (Android App) for MegaSquirt available for free!
Like MSDroid on Facebook
1993 Chevrolet Cavalier Z24
3400 Turbocharged Intercooled
MS3 v3.57+MS3X
93white3400z
Postby LT401Vette » Sun Mar 20, 2011 12:51 pm
Hmm, not reproducing. Maybe let me know what i am doing different
I took an old msq from MSnS-extra format 026h4*********
-- Double click on it.
- Prompted if i want to use an existing project
- Click No, so use Temp Project
- Got prompted that TS does not have the ini, whould I like to browse for it
- Click yes, browse to ini
- Select the MSnS-extra format 026h4********* ini
It opened.
LT401Vette
Postby jsmcortina » Sun Mar 20, 2011 12:55 pm
Automatic update does not appear to be working for me. I click on check for updates and it says that it is Checking but nothing else happens.
Linux running 0.999.9m
Postby LT401Vette » Sun Mar 20, 2011 1:12 pm
Dan, Do you have the inc files you need?
If you have the Ronnie project open, that is the right place for the inc files.
But nothing has changed for inc handling in over a year, so there should be no change there. I will see if I can reproduce.
LT401Vette
Postby 93white3400z » Sun Mar 20, 2011 1:13 pm
Humm, just noticed the MSQ I was tried to load from that guy seems totally messed up: http://www.turbocamaroproject.com/megas ... _06_22.msq
Maybe the bug is not too bad then, I guess you could still handle that and say invalid MSQ instead of crashing tho :D
MS3 v3.57+MS3X
93white3400z
Postby LT401Vette » Sun Mar 20, 2011 1:16 pm
James, Interesting... I just tried an auto update on an old Linux machine with 32 bit Ubuntu and 0.999.9h, nothing...
Same results as you. Not sure why, I'll have to check. I guess you need to use the tar for now.
LT401Vette
Postby dan187 » Sun Mar 20, 2011 1:59 pm
hmm ok, should I try remaking the inc files with easy therm and putting them in the folder?
Presumably nothing has changed in the megasquirt itself?
Dan
dan187
Postby LT401Vette » Sun Mar 20, 2011 2:18 pm
nope... All those calcs are done straight from the inc files for MS1 and TS would / couldn't update the firmware.
LT401Vette
Postby BenGTT » Sun Mar 20, 2011 3:04 pm
Congratulations Phil for the v1 release :)
BenGTT
Postby gurov » Sun Mar 20, 2011 10:54 pm
gauge copy-paste via ctrl-c and ctrl-v pastes two objects. so you end up with 3 of the same.
2014 BMW X1 35i MSport - single turbo N55 - stock!
2012 BMW X3 35i MSport - single turbo N55 - stock! (GONE)
2004 BMW 325xi Turbo MS3/X M54B25 j&s slc_oem
1994 Toyota Supra Twin Turbo - AEM EMS v2 - 2JZ-GTE slc_oem
2004 Nissan SE-R SpecV Turbo - MS3/X QR25DE j&s slc_oem (SOLD!)
gurov
Postby ChevytoyR1 » Sun Mar 20, 2011 11:15 pm
auto up date doesnt work ither for me on my old windows xp ibm t30 laptop .. but auto updated fine on my new windows xp dell laptop
ChevytoyR1
Postby Kurt A » Mon Mar 21, 2011 12:20 am
Congratulations on the 1.0 Phil :yeah!:
Rotax 912 turbo'd under construction MS2 Extra
2005 Mustang GT, turbo'd, aluminum heads, MS2 Extra
1928 Ford Coupe, 545BBF,671 blower, Squirted by MS2 extra 3.1.0, V3.0 Board
Kurt A
Postby elaw » Mon Mar 21, 2011 6:33 am
Phil,
Installed 1.0 on my laptop running XP and desktop running Win7. On both, I now get the error below at startup. This is with MS3 firmware v1.0.0. The dash on the laptop is highly customized but the desktop one is standard. Any ideas?
Edit: forgot to mention above, TS appears to work fine after acknowledging the message.
Eric Law
elaw
Postby jsmcortina » Mon Mar 21, 2011 7:22 am
Those warning messages are long-standing mistakes in the ini file that TunerStudio was previously silently ignoring (so we didn't know they were there.) I've already fixed them up for the next MS3 1.0 and 1.1 releases.
Postby 24c » Mon Mar 21, 2011 12:32 pm
jsmcortina wrote:Automatic update does not appear to be working for me. ...
FYI, Phil no problems here on OSX 10.6.6 and Linux Mint 10, moving from 0.999.9j to 1.0, TunerStudio detected the update, downloaded and then restarted faultlessly. 8)
Yamaha YZF1000 MSExtra 3.1
24c
Next
Return to Tuner Studio
Users browsing this forum: terryly and 1 guest
