TunerStudio MS 1.0 Released
Re: TunerStudio MS 1.0 Released
Update does great!!
I only still get the K version in top of the programm?
Thanks and greetings,
Erik
Erik
I guess it didn't update then..!
The release says "TunerStudio MS v1.0" in the title bar.
Win7 starter on a netbook......
I did the auto update from TS and TS wouldn't run anymore! I uninstalled and down loaded 1.0 from the TS site, reinstalled. Voila!! Up and running!!
Works great.
Works great.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
It is running now!!!
Is there a way of rolling back my install version?
I tried running the previous version setup file but the software tells me I have a newer version so it won't install.
That's weird, I did not have that experience. Downloaded the 0.999.9k setup, ran it, didn't get any errors and it seems to have worked (when I launch TS it now says 0.999.9k in the title bar). This is on Windows XP.
Eric Law
first time i updated it stayed on version k, i did it again and its now 1.0 i dont know whats up with that, but it worked the second time...
95 escort gt BPT - MS2E/ms2extra pre3.3alpha5 gslender v2.8 - E85 - 256/250 on mustang dyno at 10psi, now tuning for gtr turbo
So today I upgraded to TunerStudio 1.0 to tune my friends MS1, but when I went to the VE Analyze Live tab it just sat on the loading screen. I tried closing the program and same thing happened, and I also created a new project to have the same with happen. I wasn't ever able to load VE Analyze Live and had to downgrade to 0.999.9o.
One thing I saw now for this new version is that you cannot open several windows, for example Ignition 1 and Ignition 3.
Now, when you have the ignition window open, you cannot check anything else until you close it.
Did you do this change on purpose?
EDIT: From what I tested so far (and not all) only the Engine Constants will alow you to open another window simultaneously.
See if you have "modal" enabled.
~You are absolutely correct!jsmcortina wrote:See if you have "modal" enabled.
Not sure why that changes (if it was me, or the upgrade, but I suspect me) but now it's back again.
Thanks!
Awesome! Updating now!
1992 Volvo 740 Wagon - Beater Car...CAI, 16T, catback, MS3/MS3X, & HID's
1996 Eagle Talon TSi AWD - Daily Driver...RAI, Big 16g, 3" TBE, HID's, etc.
elaw,
if you shut of "Report INI warnings" under the menu:
Options --> Advanced
Those will go away.
Those will go away.
Running the full version 1.0 up here and works great. Thanks.
-Andrew
-Andrew
-Andrew
Did you find a fix for this problem? I have the same problem and my inc files are here C:\Users\Owner\Documents\TunerStudioProjects\Turbo_Buggy\incdan187 wrote:Great software, good work.
However, I just updated to v1. Right before the update my temp sensors were correct, after update the software reloaded and the readings are now too low (just as if the calibration is wrong). Could you suggest a solution for me?
I've checked and the inc files are still in the project folder.
Regards
Dan
I looked inside the files and they look correct. I'm assuming TS just doesn't see them any more
Dodge 2.2L MPI Turbo Power Running MSnS1/Extra.
Chevrolet 5.3 LM7 running MSnS2 /Extra
Chevrolet Twin Cam 4 cyl running MSnS2 / Extra
Home of the USB data logger---> http://www.msextra.com/forums/viewtopic ... 67&t=34901
Thanks so much man. I was finally able to run TS in 15 fps without it wigging out. Job well done.
'95 Saturn SC2 SC at 15psi
MS2 V3.0 w/MS2 Extra 3.1.1 Firmware
No, but I did some digging and I found a problem that started with 9m. I haven't changed anything there in at least a year and a half, so i didn't think it could be broke, but actually it is. When it does the ini validations the project dir has not yet been set, so it never finds the inc in the project and loads the app one. Then when real data comes in it has the app level once cached.Huey wrote:Did you find a fix for this problem? I have the same problem and my inc files are here C:\Users\Owner\Documents\TunerStudioProjects\Turbo_Buggy\incdan187 wrote:Great software, good work.
Regards
Dan
There will be a patch fix out for this tomorrow.
Okay, sounds good
TS 1.001 was auto updated to my PC. Anything new?
Fiat Seicento 1242cc F.I.R.E. engine
VR sensor on 60-2, wasted spark
MS-II Extra pre3.3 a5 Gslender 2.8
It is in the change log:
http://tunerstudio.com/index.php?option ... &Itemid=61
2 fixes. Loading inc files from the project first and fixed the double pasting of gauges when using CTRL+P
