Using TS MS Lite v1.001
The VE Table under the 'Basic setup' menu does not show the 'yellow dot' any more but the VE Table with 3D graph under 'Tuning' menu does. How do I get the dot back so I can see what the kPa is when tuning, editing the table ?
Thanks,
Yellow dot on VE Table 1 gone !
Toyota Hilux 4x4 2TR-FE MS2v3.57 LPG injection
Mitsi 4G63 MS2v3.0 (WIP)
Re: Yellow dot on VE Table 1 gone !
I don't know, it should?
What firmware are you using?
sorry forgot to mentioned,
I'm using MS2E v3.57 r3.1.0
It's was working previously, and I tried and imported VE file,after that no more dot.
Thanks,
Thanks,
If importing a VE table broke it, I'm guessing there is some setting data that is messing it up.
A bad X or Y axis value?
Can you post an msq?
here it is,
I think you forgot it.
I'm having same issue what was the fix?
