I'm using the VVT driver to operate my lockup torque converter and want to add an indicator to the dash.
With the VVT being PP6 I figured Port6 would be the output channel but it isn't.
What output channel am I looking for ?
Trying to make a VVT indicator light
Re: Trying to make a VVT indicator light
This is really a firmware question, what firmware are you using?
I''m running 1.0.2
I should add that I setup the VVT output setup to control the lock-up torque converter and it works great with the following algorithm:
Power off: 0
Power on: 1
When TPS < 25% and VSS > 40 MPH
The only thing I'd like to have more is a table of load-speed so I could make it more configurable.
Power off: 0
Power on: 1
I too would like know if vvt has a port t that will drive a tunerstudio dash indicator?
Seems like every time I find my question has been asked in the forums before it's goes unanswered .. starting to think it's a sign
MS3PU/IOx/CAN-EGT/DBWx2 540ci BBC 325cc int runners (2)innovate LC2 wbo2's, Hilborn ITB injector cnvrtd to EFI, 55LB Inj, d585 coil near plg, 60-2 trg whl & cam ph snsr, Muncie 4spd w/10T VSS, Tilton 7.25" cerametalic cltch 8.5LB flywhl
The port information is covered in the manual
http://www.msextra.com/doc/pdf/html/Meg ... e-1.3.html
You need to be running current firmware.
