TS serial failure after 3 attempts
LT401Vette
Re: TS serial failure after 3 attempts
Post by LT401Vette »
would a usb-bt dongle be any help
For the PC side? What are you using now? Built in BT?
It is worth a shot if you have then just, but I am just groping in the dark :)
Breastfed
Post by Breastfed »
Every time the BT works if I go offline change back to Com1 connect with the serial cable and go online with TS > Go offline > change from Com1 to Com10 BT port > Shutdown MS >Change over to the BT dongle > Turn on MS and it connects and stays online without errors .
But shutdown TS and reopen .... failure
is there any other setting here in the config that needs enabling ?
Breastfed
Breastfed
Post by Breastfed »
yes for the PC side
Breastfed
LT401Vette
Flow Control should be disabled. I would expect the TS parameters to be setting that though.
Breastfed
Post by Breastfed »
ooop's my mistake it was disabled already
Breastfed
Post by Breastfed »
I just read the post about "where did 1.14.1 go" ....
I've installed 1.004 and there is no longer the issue with failing to connect using BT like it was with 1.14.
It looks like TS is still not connecting 100% as it will eventually go offline and then reconnect again automatically, There is constant activity with the "blue wave across the screen" just under the Tabs, all the gauges are working :D
Breastfed
WestfieldMX5
Post by WestfieldMX5 »
Try lowering the data rate to 10.
Breastfed
Post by Breastfed »
there is no error but its continually trying to establish a solid link .... Still the same no matter what the data rate setting,
I'm still running 1.004
Post by jsmcortina »
Enable the comms log debug on the communications menu and then the main TunerStudioLogFile.txt will show up all serial commands, timings and errors.
Breastfed
Post by Breastfed »
I've
jsmcortina wrote:Enable the comms log debug on the communications menu and then the main TunerStudioLogFile.txt will show up all serial commands, timings and errors.
Done ...
LT401Vette
If you check the setting in the dialog:
Advanced --> CAN Parameters
My CAN ID
is that set to 0?
I noticed in your log that it is responding to the pure serial runtime command A, but I see no responses to any CAN formatted commands, like a page read.
Breastfed
Post by Breastfed »
Did you mean > project properties > CAN Devices ?
No, he means Advanced -> CAN parameters !
Breastfed
Post by Breastfed »
Its already set to 0 ...still the same deal
Breastfed
LT401Vette
Ok, lets try this for information...
We know it is returning runtime data using the non-CAN commands, lets see if turning on CAN_COMMANDS so it uses a CAN style command to read the runtime data works.
- Open Project Properties
- Click the "Settings" Tab
- Set CAN_COMMANDS to "Activated"
- Click Ok
Then do another Comm Debug log and we can see it is responding to the CAN based runtime data command.
Also just to be sure, it is still working fine all around with a usb serial cable?
Breastfed
Post by Breastfed »
LT401Vette wrote:Ok, lets try this for information...
Yes it's working just fine with the serial cable....
Breastfed
LT401Vette
It doesn't look like we are getting any runtime data and the txmode error is generated by the firmware when it gets data while it is not expecting it, like when it is sending it.
So, here is a thought... The 1 char command seems to get through, but the 7 byte commands are not getting through right. I don't see this setting in the dialog you have posted above, but usually BT Adapters have a setting to turn echo off. Is there an echo off setting somewhere under one of the other buttons?
Breastfed
Post by Breastfed »
I don't see any other setting that refer to the "echo off" ... switch's or button's in the dialog,
perhaps I should try another laptop with XP on it and see how ! This laptop has win7 it's been reasonably good so far maybe the BT is a little funky ??
Breastfed
WestfieldMX5
Did you ever got it working?
Mine has always worked flawlessly with MS2E, but I cannot get it working with MS3 (same errors like yourself).
LT401Vette
Give TS 1.17 a try. I made a number of comms changes specifically to help BT, including that error which seemed to come up with some adapters.
