unable to locate serial port drivers?
nismoautoxr
Post by nismoautoxr »
I have made several attempts to download tuner studio to my laptop on windows vista with the newest version of windows explorer and it downloads and installs but when I start the program it gives me an error message that says "unable to locate port drivers ". The message then asks me if I would like for the computer to initialize the drivers , the tunerstudio box just hangs there and says "initializing drivers" but it neveer does. I have to restart the computer to get that to go away.
I had tuner studio on this laptop before but was having some issues with it so I uninstalled it and downloaded the latest version and here I am . Help Phil!!
Ricky-
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
LT401Vette
Re: unable to locate serial port drivers?
Post by LT401Vette »
Didn't you email me this morning?
You never got back?
Better here anyway...
Is it a 64 bit Vista?
nismoautoxr
No Phil, that wasnt me on email. My vista says its a 32 bit version .
Ricky-
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
LT401Vette
Actually, It looks like it was someone else... Sorry my error.
The one cause for this is if you have a 64 bit Vista and only a 64 bit JRE installed.
The way I have TS packaged, the 32 bit driver is in place.
So you either need to change the RXTX driver to the 64 bit one or install a 32 bit JRE.
The 32 bit JRE can be found at;
http://www.java.com/en/download/manual.jsp
The 64 bit driver is located in:
[TunerStudioInstallFolder]\lib\alternateLinuxDrivers\win64\
Copy the rxtxSerial.dll file over the one in [TunerStudioInstallFolder]\lib.
LT401Vette
nismoautoxr wrote:No Phil, that wasnt me on email. My vista says its a 32 bit version .
Ricky-
Ok, then I'm not sure why this would be.
What installer did you use?
nismoautoxr
install shield ? Is that what youa re talking about?
Ricky-
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
LT401Vette
Yes, what version, what was the file name.
LT401Vette
Scratch the above... The driver is missing in the 1.14.1 installer.
When I realized there were 2 people reporting this problem on the same day and I haven't seen the 64 bit issue in a very long time, I checked the patch release installer.
I just posted a 1.14.1a installer. It is the same version TS but the driver in in it.
Download and install over your current and it should be fixed.
http://tunerstudio.com/index.php/downloads
Thank you for bringing this to my attention.
nismoautoxr
Thanks Phil . It worked like a charm after that . I appreciate the quick attention sir .
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Jaimatz
Post by Jaimatz »
Hello I have the same issue with the version TunerStudio For Mac OS X 10.5+ for my Macbook, Could you upload the drivers too please?
LT401Vette
The driver is in all the current installers, the installer without the driver was only out a day or 2 a few months back. So I'm thinking there is a different problem.
What version TunerStudio?
What error messager are you getting?
Jaimatz
Post by Jaimatz »
The versión is TunerStudioMS v1.14.1.pkg and the message is "Unable to locate serial port drivers"
LT401Vette
Something that has happened to a couple people now and I think is what happened here.
The librxtxSerial.jnilib that is distributed with RXTX does not work in 64 bit mode, the one I distribute with TS does. However, a couple times now it turned out that some how or maybe some other app had installed the standard 32 bit only RXTX driver and it was getting picked up instead of the one bundled with the app.
Check the dir:
/Library/Java/Extensions/
See if there is a librxtxSerial.jnilib in that dir, or anywhere else for that matter. If there is, either delete it or replace it with the one bundled with TS.
I need to check to see what i can do to make sure the one I bundle with TS is used before the the one in /Library/Java/Extensions/, I assumed the working dir was in the path sooner, but I better check that as it obviously seems to be getting trumped by what ever is in/Library/Java/Extensions/
Jaimatz
Post by Jaimatz »
Hello the folder is empty, any other suggestion?
LT401Vette
If you download the tar.gz file
extract it
then double click the TunerStudioMS.jar file
Does that work?
I may need to see your TunerStudioLogFile.txt as you must have some other odd problem occurring.
Jaimatz
Post by Jaimatz »
where is the TunerStudioMS.jar file? I can't find it.
LT401Vette
When you download the tar.gz file, OS X will automatically extract it to your downloads folder. In that folder there will be a file called TunerStudioMS.jar
Jaimatz
Post by Jaimatz »
The only file that downloaded was TunerStudioMS_v1.14.1.pkg, and already I've tryied to download again and I got the same file without TunerStudioMS.jar
Jaimatz
Post by Jaimatz »
I found the file TunerStudioMS.jar but when I click on, the same message appears and when I click Yes, the app stands by "Initializing Serial Drivers" and nothing happens
LT401Vette
The TunerStudioMS.jar that needs to be clicked is in the tar.gz file...
Download this:
http://www.efianalytics.com/TunerStudio ... .19.tar.gz
Let OS X extract that, then double click on the TunerStudioMS.jar in the folder it was extracted to.
This version will create a TunerStudioAppDebugFile.txt in your TunerStudioProjects folder.
Please send that to me.
