Page 11 of 11
Re: $7 bluetooth WORKING on MS1!
Posted: Thu Nov 26, 2015 2:04 pm
by red-racing
Hi.
I have a HC-05 connected to my ms2extra 3.3.3.
The problem is when I power up the ecu with the hc-05 attached, the ecu fails start up, and injectors are set to high. (nothing works)
BUT, if I powerup the ecu first, and then attach the HC-05 it works perfect.
So the HC-05 have to send something thats disrupts the ecu in start up.
someone have a solution for this?
Posted: Thu Dec 03, 2015 3:01 am
by red-racing
red-racing wrote:Hi.
I solved the problem by using a programable output, and put a 1 sec delay on the ground to the BT-module.
But strange only I have this kind of problem
Posted: Fri Dec 18, 2015 1:13 am
by dnz
Has anyone used one of these? Seems like the mini USB is a nice feature for power, I don't know how you would change the baud rate with only the one serial connector though??
http://www.ebay.com/itm/RS232-5V-Blueto ... xy4fBTkBLh
Posted: Fri Dec 18, 2015 9:07 am
by kjones6039
dnz wrote:I don't know how you would change the baud rate with only the one serial connector though??
Via the serial port, I suspect. That's how mine works, anyway.
Posted: Fri Dec 18, 2015 9:27 am
by Tony Evo
I bought one of these , and I can not reprogram it , it does not take the AT commands ,
Posted: Fri Dec 18, 2015 9:45 am
by Boshnakov
I am using the same, 6 months already. Bear in mind that RX/TX pins are reversed. It took me about a week of hair pulling to figure that out. Anyways, it works fine 7-10 times/sec refresh rate. Range is not spectacular though, I can move only close the car and the board is in the feet of the right seat.
Baud rate is changed via a serial terminal. There are specific commands for this.
For a basic tuning it is ideal.
Posted: Fri Dec 18, 2015 10:31 am
by Six_Shooter
Sounds like you might have an early MS2 CPU that are known to go into bootloader mode if there isn't 5V present in one of the pins associated with comms (I don't recall which one off hand). Diyautotune has a modification for their USB to serial adapter that they sell to get around this.
Posted: Fri Dec 18, 2015 1:00 pm
by dnz
How do you connect to it via serial? Considering it only has the serial connector for the MS side, not the PC, or are there points to solder to on the board?
Posted: Fri Dec 18, 2015 1:19 pm
by Boshnakov
You need the proper cable to connect it to PC. Search for the rs232 pinout, I cannot remember but I think I used a null modem cable that is crossed. One thing for sure - I had to reverse the rx/tx pins on the MS side for it to work. I also exposed the pins on the BT board in order to fit in and added a 5v power from MS to one of the unused pins.
This is kind of strange but works ok. You could use some adapter or make it yourself from two db9 connectors. You also need to see the led. It informs you when you have a connection.
Posted: Wed Mar 02, 2016 12:07 pm
by MostHated
What is the typical refresh rate of the more expensive ones? I have one of these at my disposal I can use.
http://www.amazon.com/gp/product/B0046S ... ge_o02_s00 , Also what is the refresh rate of the $55 one that DIY recommends and sells? I want to get whatever has the best refresh rate.
Posted: Wed Jul 13, 2016 5:52 pm
by Dennis_Zx7r
Just another success story:
I tried many things on my MS2 with a HC-06 module (~5€ on local ebay, including a regulator making it rated for 5V). Getting it to work and switching the baud rate was very easy on an arduino, but I thought i could just solder the wires to the DB9 input - did not work, cost me a lot of time to figure out why.
Ended up soldering TX to pin 12 and RX to pin 11 on the 232 chip. Chip gets +5V and ground from proto area.
Works nice with android apps and laptop.
Posted: Mon Nov 21, 2016 2:35 am
by kikkegek
landmer wrote:TheWoo wrote:I have been trying to do this following the information on this thread, but the board i have seems to me a later version. Markings read BT <-> RS232 V
1.3. all the ones in the guides seem to be 1.2.
Not a problem i thought, I jumped the pins and managed to get it all configured, and i can see the device from my Android device with my settings.
The issue comes when i tried to attached the 5v+ the the 9-pin connector, there apears to be a component on these later versions, any ideas where to get next?
And the underside.
Did you find where to connect the 5v supply on the v1.3 card? I'm having the same issue..
HELP?
Did anybody get this V1.3 version to work?
AT commands returned OK.
but where do I connect this 5v? the V+ pad id blocked by a part
Posted: Mon Nov 21, 2016 9:34 am
by kikkegek
I solved it for the V1.3 dongle.
just connect the pin9 (5V) to the breakout pin VCC like in this photo. and voila...it works
Posted: Mon May 08, 2017 6:32 am
by Crazy2287
Hello all i just finished a guide, that is hopefully fairly fool proof, on specifically getting one of these HC-05 devices working onboard an MS-ecu. Find the link below.
http://www.msextra.com/forums/viewtopic ... 23&t=65858
