Page 1 of 1
Do I need to use Injector Bank2 in TS
Posted: Mon Feb 13, 2012 10:42 pm
by aut0m4tic1
I just built a DIYPNP for my turbo 93 accord f22a6. In the setup page for the honda
http://www.diyautotune.com/diypnp/apps/ ... z6-mt.html it has me hook up inj1 and inj2 to the ecu connector. Does this mean I need to use Bank2 under injector characteristics?
Thanks in advance for any help
Cory
Re: Do I need to use Injector Bank2 in TS
Posted: Tue Feb 14, 2012 5:05 am
by jsmcortina
Only if you have a different type of injector connected to bank 2.
That's why it is called "Different bank 2 setting"
Posted: Tue Feb 14, 2012 11:36 am
by aut0m4tic1
James:
Thanks for the quick reply. New to megasquirt here and just wanted to make sure. I hope to do a writeup on my accord when Im done so others dont have to do all the same work Ive had to.
Thanks again
Cory.
Posted: Tue Feb 28, 2012 3:22 am
by M30guy
What would this be used for?
Posted: Tue Feb 28, 2012 3:26 am
by jsmcortina
As I wrote here.
jsmcortina wrote:Only if you have a different type of injector connected to bank 2.
Posted: Tue Feb 28, 2012 4:26 pm
by M30guy
So on a 6cyl
3 injectors are 42# and the other 3 could be 60#?
Just curious who would use something like that or what it's for.
Posted: Tue Feb 28, 2012 4:41 pm
by dontz125
A setup like this would be used in a staged injection arrangement; the smaller injectors would usually be the "low-speed" set, with the larger set adding in somewhere closer to WFO.
