Do I need to use Injector Bank2 in TS
aut0m4tic1
Post by aut0m4tic1 »
I just built a DIYPNP for my turbo 93 accord f22a6. In the setup page for the honda http://www.diyautotune.com/diypnp/apps/ ... z6-mt.html it has me hook up inj1 and inj2 to the ecu connector. Does this mean I need to use Bank2 under injector characteristics?
Thanks in advance for any help
Cory
Re: Do I need to use Injector Bank2 in TS
Post by jsmcortina »
Only if you have a different type of injector connected to bank 2.
That's why it is called "Different bank 2 setting"
aut0m4tic1
James:
Thanks for the quick reply. New to megasquirt here and just wanted to make sure. I hope to do a writeup on my accord when Im done so others dont have to do all the same work Ive had to.
Thanks again
Cory.
M30guy
Post by M30guy »
What would this be used for?
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
As I wrote here.
jsmcortina wrote:Only if you have a different type of injector connected to bank 2.
M30guy
Post by M30guy »
So on a 6cyl
3 injectors are 42# and the other 3 could be 60#?
Just curious who would use something like that or what it's for.
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
dontz125
Post by dontz125 »
A setup like this would be used in a staged injection arrangement; the smaller injectors would usually be the "low-speed" set, with the larger set adding in somewhere closer to WFO.
