Changing Bar Gauges increase direction
wrenchdad
Post by wrenchdad »
Guys,
Is there a way to make the bar gauges go from right to left instead of the normal left to right on increasing input?
Also while on the subject of bar gauges is there a way to make one have a ZERO at the center of the bar? Say to use it for O2 correction so that centered its ZERO correction.
thanks wd
LT401Vette
Re: Changing Bar Gauges increase direction
Post by LT401Vette »
I _thought_ you just had to select "Counter Clockwise Rotation" in the Properties Menu.
But I just tried it and it appears I have not yet put support in the bar graph for reverse motion.
So I guess you can't.. I'll have to add that.
There is no center based bar, but if the above worked, you could make one pretty easy using 2 bar graphs.
wrenchdad
Post by wrenchdad »
LT401Vette wrote:I _thought_ you just had to select "Counter Clockwise Rotation" in the Properties Menu.
Yep, That's what I tried but didn't change the direction.
thanks, wd
LT401Vette
I did activate it today.
While doing so I nodiced the dashed bars are already honoring the reversed rotation.
wrenchdad
Post by wrenchdad »
COOL !!! thanks :yeah!:
wd
wrenchdad
Post by wrenchdad »
OH, I forgot to ask is that in the release version or beta OR both?
thanks again, wd
LT401Vette
I'm working with the beta, I don't think the Dashed bar renderer has changed since 1.004, but would have to try it.
