Page 1 of 1
Changing Bar Gauges increase direction
Posted: Wed May 09, 2012 11:20 pm
by wrenchdad
Guys,
Is there a way to make the bar gauges go from right to left instead of the normal left to right on increasing input?
Also while on the subject of bar gauges is there a way to make one have a ZERO at the center of the bar? Say to use it for O2 correction so that centered its ZERO correction.
thanks wd
Re: Changing Bar Gauges increase direction
Posted: Thu May 10, 2012 6:05 am
by LT401Vette
I _thought_ you just had to select "Counter Clockwise Rotation" in the Properties Menu.
But I just tried it and it appears I have not yet put support in the bar graph for reverse motion.
So I guess you can't.. I'll have to add that.
There is no center based bar, but if the above worked, you could make one pretty easy using 2 bar graphs.
Posted: Thu May 10, 2012 3:00 pm
by wrenchdad
LT401Vette wrote:I _thought_ you just had to select "Counter Clockwise Rotation" in the Properties Menu.
Yep, That's what I tried but didn't change the direction.
thanks, wd
Posted: Thu May 10, 2012 3:17 pm
by LT401Vette
I did activate it today.
While doing so I nodiced the dashed bars are already honoring the reversed rotation.
Posted: Thu May 10, 2012 3:28 pm
by wrenchdad
COOL !!! thanks :yeah!:
wd
Posted: Thu May 10, 2012 3:33 pm
by wrenchdad
OH, I forgot to ask is that in the release version or beta OR both?
thanks again, wd
Posted: Fri May 11, 2012 5:24 am
by LT401Vette
I'm working with the beta, I don't think the Dashed bar renderer has changed since 1.004, but would have to try it.
