Perhaps just a minor name change.LT401Vette wrote:Do you think that might be clearer than the "AFR Target Temperature Adjustment" Curve in the advanced tab?
That is essentially an AFR add / subtract curve.
(warmup) AFR target vs. CLT is the goal , the WUE curve is just the calculated fuel to get you there.
I (ab)use the whole WUE table the same way, goes out to> 350F
(aircooled motor)
Same with "cold timing".
