It is a non trivial change to support this right, but agreed it is worth doing. Not done yet though.
There are a couple priority items for this new beta getting attention 1st, but I do intend to get this in this beta cycle also.
Bug: VEAL goes haywire on VE2 with MAF
Re: Bug: VEAL goes haywire on VE2 with MAF
Do you want to share what you are working on, we are curious? I have noticed that the stream of betas have slowed, could that be a sign that major new features are in the wings?LT401Vette wrote:There are a couple priority items for this new beta getting attention 1st, but I do intend to get this in this beta cycle also.
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
After a release finally goes to stable. That is when I get to go and make the bigger change, changes that potentially break things.
LT401Vette wrote:After a release finally goes to stable. That is when I get to go and make the bigger change, changes that potentially break things.
I think I made that comment because I feel you are using the terms alpha and beta loosely. Where I come from, the transition from alpha to beta is when the product is feature complete, and if I am not much mistaken you have been adding features in betas...
Any update on the progress of this particular change, btw? VEAL must use the correct AFR target to be useful without a lot of custom filtering.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Bumping this one again, anything happening regarding rewriting this feature?
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
The next major release of TS is under heavy development. No betas or alphas have been released yet, that will likely still be a couple more months.
Heading for 3.0? It will be exciting to see what you pull out of the hat this time.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
