Shivering in the Lotus trying to Autotune my WUE on single digit mornings, I have some questions;
I can't seem to save my edits to the "AFR Target Temperature" curve. It returns to the default every time I start TS, and I find myself tuning to the wrong curve, and have to wait for the next cold start. I tried saving the tune after editing the curve, but still see the same curve.
Do I need to disable any other enrichments to run the autotune?
Do I need to push my AFR/EGO "Active above" temp higher out of the warmup range?
I love the real time Error and Recc. WUE plots !
WUE Autotune Questions
Lotus Esprit w/MS3x, COP, Sequential, GM TB&IAC. Hall sensor on 36-2 crank,1 pin VR cam. MapDaddy, AEM X WBO2, Clock&Knock boards.
Subaru WRX hybrid w/MS3PNPPro SW0205, STi cams, VF39 turbo, 830cc injectors, VW boost solenoid.
MS3 1.5.1
TS v3.0.28
MS3 1.5.1
TS v3.0.28
Re: WUE Autotune Questions
Updated to the 2.5 05 Tunerstudio, and still can't save edits to the AFR Target Temperature curve in the warmup auto tune. Any ideas out there?
MS3 1.5.1
TS v3.0.28
MS3 1.5.1
TS v3.0.28
Somehow your original post slipped through the cracks. I am reproducing that same problem.
Is there an update on this? I am having the same issue.
it is almost like the default setting is backwards. The help file says normally you want the stoich afr for warmup.
It is fixed in the current beta.
That needs to be promoted to stable soon.
