VEAL tuning secondary injectors
Re: VEAL tuning secondary injectors
Post by LT401Vette »
See attached.
chase350z
Post by chase350z »
help
with the new 1.5.1 firmware i cant find the Ve table 1 throw Ve table 4 section in the maincontroller.ini file to cancel out the over run filter for staged.
could i just add the custom ini file to the projectscfg file to make it work.
thanks chase
06 z33 with 2jz gte vvti/ bw 369sxe / mspnp pro
sschutte
Post by sschutte »
chase350z wrote:with the new 1.5.1 firmware i cant find the Ve table 1 throw Ve table 4 section in the maincontroller.ini file to cancel out the over run filter for staged.
I am not sure I understand?
Can you please break this down so we can get a clear understanding of:
  • What you are tyring to accomplish
  • The steps you have already tried(and their outcomes)
  • What issues you ran into. (Error messages or screenshots would be great)
Sharing your MSQ would help us when we go to review/reproduce the issue that you are reporting.
:msq:
chase350z
Post by chase350z »
:msq:
commenting out the overrun filter for the auto-tune in the main controller with a ; with the 1.5.1 firmware the ve table 1, ve table 2, ve table 3, are missing i looked over the hole main controller file a few times and could not find it like it was in the older firmwares .
thanks chase
Brian H EFI
Post by Brian H EFI »
I am not sure what text editor you are using but if you press Ctrl + f it should open a find dialog, then if you search the ms3pro.ini file for "Fuel VE Table 1" you should find them they start at line 12431.
chase350z
Post by chase350z »
Yea there is only one spot with fuel ve tabes and it doesn't have the over run filter in it at all its not like the past firmware i guess
