VEAL tuning secondary injectors
Re: VEAL tuning secondary injectors
See attached.
help
with the new 1.5.1 firmware i cant find the Ve table 1 throw Ve table 4 section in the maincontroller.ini file to cancel out the over run filter for staged.
could i just add the custom ini file to the projectscfg file to make it work.
thanks chase
thanks chase
06 z33 with 2jz gte vvti/ bw 369sxe / mspnp pro
chase350z wrote:with the new 1.5.1 firmware i cant find the Ve table 1 throw Ve table 4 section in the maincontroller.ini file to cancel out the over run filter for staged.
I am not sure I understand?
Can you please break this down so we can get a clear understanding of:
- What you are tyring to accomplish
- The steps you have already tried(and their outcomes)
- What issues you ran into. (Error messages or screenshots would be great)
Sharing your MSQ would help us when we go to review/reproduce the issue that you are reporting.
commenting out the overrun filter for the auto-tune in the main controller with a ; with the 1.5.1 firmware the ve table 1, ve table 2, ve table 3, are missing i looked over the hole main controller file a few times and could not find it like it was in the older firmwares .sschutte wrote:chase350z wrote:with the new 1.5.1 firmware i cant find the Ve table 1 throw Ve table 4 section in the maincontroller.ini file to cancel out the over run filter for staged.
thanks chase
I am not sure what text editor you are using but if you press Ctrl + f it should open a find dialog, then if you search the ms3pro.ini file for "Fuel VE Table 1" you should find them they start at line 12431.with the new 1.5.1 firmware i cant find the Ve table 1 throw Ve table 4 section in the maincontroller.ini file
Yea there is only one spot with fuel ve tabes and it doesn't have the over run filter in it at all its not like the past firmware i guess
