Hey Phil or anyone , I can't seem to find a traction control indicator, is there one?
Thanks,
Nolan
Re: traction control indicator
? Phil?
It's most likely the issue is related to the firmware you're using... all the indicators on the TS dash are defined in the .ini file that comes with the firmware.
So you might be better posting in the forum that corresponds to the firmware you're using.
Eric Law
Was there ever an answer to this just downloaded the latest pre1.4alpha2 and there does not seem to be one in there.
figured it out. in designer mode right click an indicator: in properties, select output channel and use 'tc_retard'
