microsquirt module spark
when use aled& wled for spark c&d what do i have to turn on? i see a pullup resistor is need,but i just cant seem to find were to turn the outputs on. im using msextra 3.3.1 usm .
62 f100,uni body,4.6 motor&updated chasis, ms2 micromodule
Re: microsquirt module spark
Assuming you have an 8-cylinder engine, simply set it for wasted spark and it will use sparks C&D on ALED and WLED.
It's worked out from what you select at Number of Coils in Ignition options and how many cylinders, etc you have selected in Engine and Sequential Settings.
Cheers Luke
Cheers Luke
thx. ill try it tomorrow.
