Phil,
Just started using average MPG and noticed that it will hang up unless TS is restarted every time. My car has a onboard PC so TS isn't restarted every time I use it. TS might even stay running for weeks without a shutdown/restart. Just seems that the average function should be tied to engine starts, and reset when RPMs go to zero?
thoughts?
thanks
wd
PS I am running the latest TS ( 2.5.14) but still using MS3 RC1 haven't upgraded to 1.3.0 release yet, that's on the todo for tomorrow.
Average MPG hangs
Re: Average MPG hangs
It is on the todo to have a few reset methods.
I'll have to look at this though, it shouldn't be hanging even if not reset.
Thanks Phil !!
One other unrelated thing, my car computer uses a small 8 inch touch screen, and when in designer mode, the on screen list goes off the bottom of the screen when doing an edit of a indicator or gauge.
Any way to make it where it would scroll or two columns wide? OR have TS setable for screnn size?
Just asking
wd
Just asking
wd
