testing the TunerStudio Beta 2.5.20
with the MS2/Extra pre-3.4 alpha 1 release
and have this problem http://www.msextra.com/forums/viewtopic ... 55#p398065
since the TunerStudio 2.5.05
not able set values on "Injector Dead-time/PWM" for Bank2
Re: not able set values on "Injector Dead-time/PWM" for Bank
Here just in case the newest MSQ attached: are the Bank2 fields unlocked if you open it e.g. with the TunerStudioMS_Beta_v2.5.20 - like this?
On the "old" versions it's working just fine:
Thanks-
Yes, that's an ini error. I see it now.
In the ini file,
needs changing to:
In the ini file,
Code: Select all
field = "Injector2 Dead Time", injOpen2, { injctl && injctl2_2 }
field = "Battery Voltage Corr.", battFac2, { injctl && injctl2_2}
Code: Select all
field = "Injector2 Dead Time", injOpen2, { injctl }
field = "Battery Voltage Corr.", battFac2, { injctl }
