Failed CRC check
Re: Failed CRC check
You haven't by chance tried a stable 3.3 firmware?
Do you mean other than 3.3.1a?
Any 3.3, I was going by the picture where it says you are running a 3.4 alpha
Yes I currently have 3.3.1a installed and it behaves the same with the CRC errors as pre3.4alpha2.
Did you ever solve this issue?
MS3PU/IOx/CAN-EGT/DBWx2 540ci BBC 325cc int runners (2)innovate LC2 wbo2's, Hilborn ITB injector cnvrtd to EFI, 55LB Inj, d585 coil near plg, 60-2 trg whl & cam ph snsr, Muncie 4spd w/10T VSS, Tilton 7.25" cerametalic cltch 8.5LB flywhl
No, any thoughts.
Do you have IOx on the CAN bus?
I have an AIM dash on the can bus.
There's been several different thread subjects that are investigating possible CAN issues. Here's a thread im involved in that gives some troubleshooting ideas for CAN issues.
http://www.msextra.com/forums/viewtopic ... 85#p446485
I am having data logging problems and I have had failed CRC check errors as well.
I am going to try the suggested troubleshooting ideas this weekend.
I created a new project without CAN and connected to my controller (ms3x) and loaded the setting from controller into tunerstudio. Tunerstudio still datalogs the CAN device and automatic datalogging is working again. Looks like that fixed it ..dll67 wrote:There's been several different thread subjects that are investigating possible CAN issues. Here's a thread im involved in that gives some troubleshooting ideas for CAN issues.
