CAN Devices tab grayed out
I have an MS3 running firmware 1.3.0 with a CAN device (declared under CAN Devices).
I tried to load a new .ini to the CAN device, however by accident I changed the the main controller's ini instead (ouch).
I reloaded the main controller's ini, switch the ECU on to re-read the ECU settings, then tried to go to CAN devices to actually load the .ini file for the CAN device - however the CAN devices tab is now grayed out in this project no matter what I do!
The man behind MS Labs
Re: CAN Devices tab grayed out
If you get the main controllers ini back to a device that supports CAN devices, the CAN Devices tab should go back to enabled.
I've reloaded the MS3's controller .ini file, I'm actually online with the ECU, and the CAN devices tab is still greyed out.LT401Vette wrote:If you get the main controllers ini back to a device that supports CAN devices, the CAN Devices tab should go back to enabled.
Which firmware?
1.3.0 release.
Should I email you my project folder?
Yes, That might help...Should I email you my project folder?
Emailed.
Got it...
If you set CAN_COMMANDS to Deactivated, click Ok,then set it back to Activated and click Ok, it fixes the project properties.
That worked, thanks!
