Dear all (Phil)
For the past few days have done some datalogging while tuning the Ve table and have only just noticed what I think is a problem (it could be me?) when hitting the space bar to mark the log Veal turns off??
Surely not by design...could it be me?
John
P.S.
don't think you need a log or Msq for this but then again I could be wrong ( usually am )
SORTED Ms v2.6.01 spacebar marking datalogs stops VEAL?
- Running MSx/Extra
Re: Ms v2.6.01 spacebar marking datalogs stops VEAL?
In windows ( or most OS's), if a button has focus and you press the space bar, the Button will get pressed.
So if you are on the VE Analyze tab and the last thing you clicked was Start Auto Tune, then that button would have focus and would get pressed. This specific case it is not desirable, but I'm not sure what else to do.
- Running MSx/Extra
Thanks for the rapid response,I get what you say..so..."Start auto tune "...."maximum cell value change"..."OK"....and then hitting the space bar doesn't stop veal...
Sounds good to me..
Thanks Phil.
John
Sounds good to me..
Thanks Phil.
John
Unfortunately, moving the focus elsewhere can trigger another undesirable response
- Running MSx/Extra
.. but if I hit "maximum cell value change", make no alterations and hit "OK" would that upset something else?
John
John
Nope.
- Running MSx/Extra
