custom filter info
nathanhardy
custom filter info
Post by nathanhardy »
im have a intake air temp heat soak issue and till i can find a tig welder i cant change it. i know its a hack fix, but im wondering what the filter code would be to limit veal to not change above a certain manifod air temp?
98 VW golf gti vr6 turbo 8:5:1 cr ported and polished full ferrea race valves train 276 cams custom short runner intake Borge 366 sx-e turbo forge wossner pistons, balanced rotating mass, limited slip 6 speed deka 750Lbs injectors on ms3pro completed AWD swap
Re: custom filter info
Post by LT401Vette »
What firmware?
nathanhardy
current firmware 3.3.x. phil gotta say thank you for all you do!
Add a custom filter:
mat > yourTemperature
where yourTemperature is the number you don't want VEAL to work at or above.
nathanhardy
thanks for some i was using IAT instead of mat
