custom filter info
custom filter info
im have a intake air temp heat soak issue and till i can find a tig welder i cant change it. i know its a hack fix, but im wondering what the filter code would be to limit veal to not change above a certain manifod air temp?
Re: custom filter info
What firmware?
current firmware 3.3.x. phil gotta say thank you for all you do!
Add a custom filter:
mat > yourTemperature
where yourTemperature is the number you don't want VEAL to work at or above.
thanks for some i was using IAT instead of mat
