changed my hardware, had big injectors 3" up stream from the valves originally, now I have appropriate sized injectors spraying at the intake valves so my eae tables are no where near appropriate, and the default starting point values would be a better starting point.
what is the best way to get the default values back in the tables?
how to reload default eae tables?
v2.2 box, ms2, dual wheel, sequential ignition, staged injection, boost control, maf
'87 VW scirocco, 2L16V, TD0-14T turbo, itbs
Re: how to reload default eae tables?
could you grab the settings from the example tune that you get with the firmware download?
yah,
was hoping for a way to import /export them like the ve and ignition tables
i believe you can use this.msqpart - Only used in the TunerStudio 1.16 and higher, this file type is of the same format as an msq, but used for saving subset of tune settings. In TunerStudio there is now a concept of "dialog settings", where when you have any tune dialog open you can select to save or load just the settings in that dialog. The msqpart extension is used to differentiate it from an msq which would contain all settings for that firmware.
Open your EAE settings dialog and open the default msq that came with your firmware using the File menu on the dialog.
File --> Load Dialog Settings
When using the "File --> Load Dialog Settings" on the dialog, TS only loads the settings in that dialog, all other settings are left alone even when loading a full msq.
figured you set up an easy way to do this
Thank you Sir!
Thank you Sir!
