i would like to add a us gal per hr gauge in the calculated field and need some help
added script but will not work
get output channel problem
thanks phil
add fuel flow us gal gauge
Re: add fuel flow us gal gauge
Gal/hr is already in the registered TunerStudio.
What are you using for a speed input?
just found the gauge
is this based on injector flow correct
i'm not using a speed pickup
phil
phil
Yes, it is based on the inputs in the dialog;
Data Logging --> Performance and Economy
speed input is for adding MPG and HP,, but not needed for fuel flow.
